emergency brake light comes on when i turn a sharp curve
tacoma man
04-27-2004, 04:14 PM
i have noticed that my emergency brake light flashes when i make a ]
sharp right hand turn. could my back brakes be bad, i just had to put front ones on it. i bought the truck used and it still had the factory
brakes on it, the truck has 117,000 miles on it
groupset
04-27-2004, 09:50 PM
you probably just need to add some brake fluid - it's a known problem with Toyotas; you gotta run the brake fluid pretty full to keep the warning light from coming on. When you go around a corner, it's shifting the fluid level enough to trigger the light.
tacoma man
04-27-2004, 10:07 PM
i would say thats it, we had to bleed the lines
when i put on new brake shoes. thanks i will
check it. i noticed it does it when im going up
hill.
hill.
tacoma man
04-27-2004, 10:10 PM
thats what it was, its down all most on the minimum
mark. im glad some one knew what they were talking about.
