Need help with a thermostat in a 92 MPV
ShootMyCars
04-26-2004, 07:44 PM
Trying to change the thermostat in a 92 MPV 2WD V-6. Went where thermostats normally are, inside the housing that the upper hose attaches to, and SURPRISE! No thermostat! Just two square ports. Anyone with info and possibly a diagram would be greatly appreciated. I can be reached direct at redofthejedi@aol.com or on AIM at redofthejedi.
Thanks!
Thanks!
1995 geo tracker
04-26-2004, 08:58 PM
it is most likely where the lower hose goes into the motor , get a haynes manuel for you model , it will show you where it is
ShootMyCars
04-27-2004, 07:42 PM
Thanks. I was able to find it. These things are completely backwards from what I'm used to.
