B20 Swap
integralover
04-26-2004, 06:45 PM
i would really like to know exactly what will i ned to do a B20 swap. and yes i know the engine would be a good thing to have. i do have a few lined up but not sure if they will come through. my mods already are listed below. i would just like to know what i will need while i'm installing to make this thing run. will i need a new ecu? fuel rail, can i keep mine? i only really have enough money just for the engine. this came at a bad time. will i need new motor mounts? stuff like that. thnx for all your help.
whtteg
04-27-2004, 12:11 AM
As long as you get either the B20z or the B20B then all you need is the motor and the intake manifold and exhaust manifold from your B18A that is in your car now. The B20 is the same motor as the B18B just with a larger 84mm bore vs the 81mm bore of the B18B/A. The same ecu you have will work and the mounts you have will work also. One question though is your car auto or 5spd? Doesn't really matter, both trannies will work with the B20, just curious.
integralover
04-27-2004, 12:26 AM
5 speed :bigthumb: great, so it sounds as if im just putting in the same exact motor but different bore. that is all i need to know. thnx for all your help whtteg:thumbsup: ill let you know how it comes out.
