87 GT-S w/ head shaved, Performance Questionsxtcbytes 04-26-2004, 04:12 PM I had my 3S-GE head shaved to the maximum, a valve job and removed all of the EGR system. I am wondering what performance+ I can expect once I get the improved sports clutch installed? NOTE: This is just my toy so pushing it to the limit is the idea. Oh, The whole A/C system, has been removed and the car is being lightened. M.WILSON 07-06-2004, 08:41 PM I Have Did A Conv On My Gt I Put The Gts Head Fully Done As Yours On To The Gt Block W/intake (in Which You Must ....must Reroute That Damb Battery To The Trunk So You Will Be Able To Get Clean Air Flow, I Lowerd My 1.25 Time From 19.95 W/ac To 16.48 W/ac And Mine Is A Convertiable More Wght.. And Also Remove C/cntrl If You Have It T/response Vis Greatly Improved ......mitt Late M.WILSON 07-06-2004, 08:43 PM I Have Did A Conv On My Gt I Put The Gts Head Fully Done As Yours On To The Gt Block W/intake (in Which You Must ....must Reroute That Damb Battery To The Trunk So You Will Be Able To Get Clean Air Flow, I Lowerd My 1.25 Time From 19.95 W/ac To 16.48 W/ac And Mine Is A Convertiable More Wght.. And Also Remove C/cntrl If You Have It T/response Vis Greatly Improved ......mitt LateHAVE YOU FOUND SOME CAMS YET I HVN TRBLE..? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
