Knocking noise when turning left
Google
Web AF
sheshell
04-26-2004, 12:18 PM
I have a similar knocking noise when I turn left. It also knocks when I go straight (after the left turn). What is this noise? My mechanic can't find it.
Thanks!
amigo-2k
04-26-2004, 01:51 PM
What year?
It could be from the sway bar bushings.
-Ryan
sheshell
04-26-2004, 06:15 PM
It's a 1994 Rodeo automatic. The knocking noise is almost in sync with the rotation of the wheel and comes from the RIGHT passenger side. If I press on the accelerator, I hear the knocking. If I let my foot off, it stops.
Davejb
04-27-2004, 02:32 PM
4X4? If so a bad CV would cause this.
sheshell
04-27-2004, 04:55 PM
I just read this article on noise and CV joints http://randrautoservice.com/service%20info.htm#cv%20boots
and you're probably right. Since there's a noise on the left turn it appears to be the right joint/boot. This site's advice is to replace the entire axle.
Thanks for the help and I'll update to let you know what it was.
Pam
sheshell
04-28-2004, 12:21 PM
Now I'm told that it can't be the CV joint bcse the noise wouldn't come from the rear. Oh, well...
Davejb
04-28-2004, 12:38 PM
You never said it was coming from the rear, that makes a big difference.
sheshell
04-28-2004, 12:55 PM
You're right (I was thinking back right passenger). Any ideas?
Davejb
04-28-2004, 02:40 PM
Axle bearings, something in the rear diff maybe.
sheshell
04-29-2004, 02:28 PM
The mechanic said it was everything in the rear: bearings, pin, shims, side gear, etc. Says it'll be about $1600.
Anything else I should have them check while I'm there (eg timing belts) at 85k miles?
Thanks.
xxcrowleyxx
05-03-2004, 09:40 PM
Thanks.
i was looking up under my back a while a go & i noticed that my 1995.5 rodeo has rubber mounts which are almost rotten. when i turn there's a sound & a feel from the back i'm pretty sure thisis the cause of the sounds. the leaf springs has rubber mounts (on both ends). Now unless u have a whine-ing noise in the wheel(s) that is a indication of a bad bearing(s). the next time you oil up or have the car greased, they are supposed to grease all the wheels or bearings too. so when u have a 10 point or a 16 point <whatever> grease up make sure they do the bearings as well.
Google
Web AF
