I`m New..I have a question
CWil92
04-25-2004, 10:52 PM
How do I get the date to be displayed on the information center...I tried holding the button for 5 seconds,and still says no date available....I was wondering if anone else had this problem and if they did how did you resolve the problem.
kentuckyjoe
04-26-2004, 07:12 AM
Set the time on the clock, and it will display the date
CWil92
04-26-2004, 07:33 AM
I took out the original radio..and put in a pioneer cd player...is there any other way to get the date to be displayed
RoraStar96
04-26-2004, 08:07 AM
I heard this happened to a fellow Aurora driver when he swapped his stock head unit for an aftermarket. Still no solution, but I will ask again.
rodtice
04-26-2004, 10:41 AM
If you remove the OEM radio your screwed for many things on the DIC. Also the steering wheel controls won't work.
CWil92
04-26-2004, 10:52 AM
oh ok...so there is nothing i can do about the date issue..besides putting the old deck back in
rodtice
04-26-2004, 11:02 AM
sorry bud, thats pretty much it. Does your ETA work?
MPG?
I have heard of someone putting the old deck behind the aftermarket deck in the huge hole back there, then your DIC would work except for time change for DST. Also temp and fan would work, but not volume.
MPG?
CWil92
04-26-2004, 11:31 AM
everything else works....i was just wondering about the date..thanks for your help...I wish there was an easy fix
kev's 96 Aurora
04-26-2004, 11:45 AM
I think the only way to fix it is a special harness..the normal radio harness is a $15 part but somewhere I read that you can get a harness for these cars that is $140 - $150 range that is supposed to make everything work aftermarket. Not sure though.
RoraStar96
04-26-2004, 03:19 PM
That must make the steering wheel controls work to. Personally my DIC is always set to the date so it would bother me to have the stock deck gone.
CWil92
04-26-2004, 04:04 PM
i like to have the date on also..I just went out and put my old deck in..and what do you know the date works now....I might have to look into a harness or something so that I can use my aftermarketdeck and still be able to use all the functions..I just like to have everything working
RoraStar96
04-26-2004, 04:11 PM
I know what you mean....good luck!
RobertHammen
04-27-2004, 05:03 PM
Crutchfield is supposed to have these harnesses... http://www.crutchfield.com
97 silverbullet
04-28-2004, 08:00 PM
its not a harness its a remote system that contects to your radio and then to your steering controls but its too much to buy if All you want is steering wheel controls for your radio, its like 150.
