95 blazer keyless remote programmingaudiotech 01-13-2002, 12:44 PM could anyone please help . I am trying to program a spare RKE for my 95 Blazer . I have tried the on off on off thing described in another thread for a 98 blazer , but did not work . I think in 95 you had to jump some pins in the computer harness , but from i have read does not match the 6 wire configuration i have in mine . Thanks ! Tireburner 01-14-2002, 08:32 AM My 95 Book doesn't show programming, so I went to the 96 book. As near as I can tell the vehicles are the same I'm not showing a change until 98, so from 94-97 this info should be correct. 1) Ground terminal No. 8(black/white wire) of Data Link Connector (DLC) Located under lower left side of dash. Reciever will respond by locking and unlocking doors within 2 seconds. Press any button of first transmitter to be programmed. Control module will respond by locking/unlocking all doors and activationg liftgate release 2) Press any button of second transmitter to be programmed. Control module will again respond by locking/unlocking all doors and activating hatch release. Remove ground from DLC terminal 8. Transmitter operation can then be verified. Attempt all functions with remote. pwauly23 02-08-2002, 01:10 PM I'm having the same problem with my RKE for a 95 Blazer. Stupid question, but I haven't done this before: How do I ground the cable? Thanks! Tireburner 02-08-2002, 01:36 PM Originally posted by pwauly23 I'm having the same problem with my RKE for a 95 Blazer. Stupid question, but I haven't done this before: How do I ground the cable? Thanks! Take a spare piece of wire. Attach it to the wire described in the vehicle. Attach the other end of the wire to either a bare piece of metal in the vehicle, or to the battery post marked (-) audiotech 02-08-2002, 06:15 PM Originally posted by pwauly23 I'm having the same problem with my RKE for a 95 Blazer. Stupid question, but I haven't done this before: How do I ground the cable? Thanks! If I may add to Tireburner's input , once you drop down the driver's side kick panel , you will notice a TRW box next to the emergency brake . you will have two connectors hooked up to the box . one connector is the incoming connector (has less wires in it ) and the other one going out to the power door locks ( has more wires ) . both connnectors have a black / white wire . you need to ground the one black/white stripe on the incoming side ( harness with less wires ) good luck ! hudd 11-01-2005, 01:53 PM I bought a used 98 blazer, the keyless entry only works on the panic button. I don't have a manual with it. I also want to know what the three buttons by the overhead lights are for? Onblsht 11-05-2005, 06:33 PM Sounds like your remote may be dead. You can try to change the battery, but usually if some buttons work, and some don't the remote itself might be defective or worn out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
