climate control lights
Google
Web AF
alxch1n15
04-24-2004, 10:35 PM
94 camry le
Hey all, I searched awhile and couldn't find anything on this. The climate control, area where the temp. stuff is, lights are out. Now, I am new to Toyota, so I'm not sure if they are supposed to light up, and if they do, how do I fix the light problem? I'm not to sure where to start.
alex
capisculosa
04-25-2004, 08:17 AM
fuse? allthough i doubt it... i had the same problem with a stereo... the backlight decided to not work... im not sure but i think its a internal thing , wiring going to from the climate control module..
AndyM1978
04-26-2004, 09:41 AM
I am willing to bet that if you "wrap" on the areas where the lights went out with your knuckles, they will flicker back on. My mom's 95 Avalon had this problem and my 92 Camry is even worse. I'll smack my climate knobs, which will make the lights work again, but then the lights on my recirc and AC buttons will go out. I can never get all the lights to work at the same time.
To get to my point, I'm pretty confident that you have loose connections to the bulbs, or the bulbs may even be burned out. Trying my "knock the dashboard" trick might narrow down the problem a little. I've heard that this erra of Toyota's have that problem. Anyone else out there know what I'm talking about?
calvic
04-27-2004, 05:16 PM
If the A/C still blows cold air while the lights are out then its just as they said poor light connection or ground. My 88 has started doing this same sort of thing. I give em a wiggle and they light up.
JJ
Google
Web AF
