changing power steering beltdrewg181 04-23-2004, 04:56 PM I am reasonable astute, but cannot find how to loosen power steering pump so I can replace the belt on 1993 Camry LE 4 cylinder. Can someone offer assistance? drewg181@yahoo.com Great car....200K + still looks sharp! Brian R. 04-23-2004, 05:40 PM Loosen both the adjuster and pivot bolts. Looking from the belt side of the engine, the pivot bolt is on the upper right side and the adjuster bolt is on the bottom right. drewg181 04-25-2004, 10:26 PM Thanks Brian, Tried it but w/o power tools there was no way to break loose those bolts. I changed the serpentine belt, but I'll have to leave the p/s belt to a shop. C'est la vie, Drew Brian R. 04-26-2004, 12:18 AM Buy the correct socket - extension - and 1/2" drive breaker bar. Unless you're 98-lb weakling, they will give. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
