Car won't startamature 04-22-2004, 11:53 AM An friend of mine has a 92 Camry. He said last week it died and wouldn't start. It had been running all week and when he went to leave the gas bar it stalled and wouldn't start. The mechanic said he needed a new distributor at a cost of almost four hundred bucks. He drove a couple hundred miles and the next day he went to start it he couldn't. He said it is doing the same thing before. I am the one going to be looking at it cause I know a little bit about cars. How can I test the distributor? What else (besides the timing) can I look at? Much appreciated. Brian R. 04-22-2004, 11:59 AM What engine? amature 04-22-2004, 12:01 PM Four cyl I think. I will ask! amature 04-22-2004, 12:11 PM Yes four but I am not sure if it is a 2L or 1.8L or if there various displacements for 1992 models. Brian R. 04-22-2004, 02:10 PM 2.2 L Not starting means that it cranks ok, but never runs? or just sits and never even cranks? amature 04-22-2004, 03:52 PM Oh yes, it cranks but does not start. I was just wondering if this is a common problem. It was running fine and the next time he went to start it it wouldn't start but it would crank. Would there be something causing the distributor to burn up or stop working? Joe W 04-22-2004, 04:50 PM It sounds like it could be the ignitor. amature 04-22-2004, 04:54 PM Where is the ignitor in the car? Brian R. 04-22-2004, 07:14 PM When it won't start. First check spark at the distributer from the coil. Crank holding coil wire 1/2 inch from ground If you have spark, scope it to make sure it is adequate in voltage and correctly timed. Low voltage is coil, timing is adjustable. If no spark, check power to coil and igniter. With ignition switch on, check that there is battery voltage at ignition coil (+) terminal. If there is battery voltage (should be), check resistance of coil cold Primary (+ to -) 0.36 - 0.55 ohms Secondary (+ to high tension) 9.0 - 15.4 kohms hot Primary 0.45 - 0.65 ohms Secondary 11.4 - 18.1 kohms If bad, replace coil If the coil is good, check resistance of signal generator (pickup coil) cold 135 - 220 ohms hot 175 - 255 ohms If bad replace distributor housing assembly If good, check resistance of crankshaft position sensor cold 985 - 1600 ohms hot 1265 - 1890 ohms If bad, replace If good, check air gap of distributor 0.2 - 0.4 mm (0.008 - 0.016") If bad, replace distributor housing assembly If good, check IGT signal from ECM If bad, check wiring between ECM, distributor and igniter, then try another ECM if possible If good, try another igniter. Ignitor is next to coil on the driver-side strut tower. Says "Toyota ignitor" on it. amature 04-22-2004, 10:41 PM Thanks I will check it out! CATS_GUY 05-10-2004, 10:19 AM I have the same problem. How much should a shop charge to fi? Brian R. 05-10-2004, 10:47 AM Depends on the time necessary for troubleshooting and the cost of the parts. Distributor is expensive. ECM is expensive. Tercel GTS 05-11-2004, 08:14 PM also check to see if the 30amp engine fuse is blown, if it is replace the condensor inside the distributor vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
