85 Chevy Pu No SparkNitWit 04-18-2004, 09:45 AM I have the same problem on my 85 305 PU. It started fine, I would be driving and would loose spark. Sometimes I wait 10-15 min and it would start and drive fine. Sometimes an hour. No rhyme or reason to it, and it didnt happen every day. (spring and summer operation) I swapped the module and it seemed ok for a few days then it started happening again. Then it just quit. No spark. I first rebuilt the distributer, new Pick up coil, module and that little round capacitor, coil, cap and rotor, everything. No spark. I got Chiltons and metered it had all the correct voltages in and out, coil etc. I then borrowed a distributer from a friend and tried it and still no spark. I ran a new ground to the block, no spark. I will check the ignition switch to make sure I am not loosing power to the distributer while starting but assuming that checks out ok, what else could it be? michelq 04-18-2004, 02:09 PM i think your p/u has electronic spark control madule. i do not remember where is located .try behind glove box or above gas pedal. most likely esc is bad pind 04-18-2004, 05:58 PM the ESC module was all in one under the distributor cap on those years. The difference was the number of pins on one end of the module. All I have done in the past to correct this issue, is replace the ESC style module with a regular one, problem solved. Maybe this helps, maybe not, good louck. CatDiesel_762 06-23-2004, 10:48 PM Pull/Disconnect the four pin connector that runs from your HEI to the the firewall. Then use a jumper wire on the wire terminals A and C that lead to the HEI. Your truck should now fire and run. If not then your pick up coil at the bottom of your HEI needs to be replaced. CatDiesel_762 06-23-2004, 10:53 PM I have 86 GMC Vin H that had the same problem. I took it to the dealer and they showed me the trick to test the spark control by jumping the A and C terminals. It showed that my ESC was retarding my HEI to a stall. Since then I have swaped out the ESC HEI for a four pin HEI. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
