cracked camry radiator repair
Google
Web AF
jstrummer
04-16-2004, 07:07 PM
The top, plastic part of my 96 camry 2.2 radiator is cracked, a 2 inch hairline at the very top. Is there some el cheapo way of repairing this? I am flat freaking broke and my wife needs the car badly.\
Thanks in advance for any help anyone can give me.
Brian R.
04-16-2004, 11:02 PM
The cheapest way to fix it is to replace it with a used part from a junk yard. Perhaps you can work out a deal at the junk yard for a trade. See if they will take your wheel covers in trade.
There is no reliable way of sealing it for pressure. You will have to replace it.
I hope someone else has a better idea.
Bossman
04-17-2004, 05:09 AM
I had mine replaced in either my 87 or 92 Camry, can't remember which now, and the reason why it was replaced instead of repaired was because it's mostly plastic instead of metal and that cannot be repaired. :nono:
The symptoms of the leak were green liquid along the top corners at each end of the radiator. Sorry, but it had to be replaced. Even the radiator stop-leak stuff one can buy in an auto parts shop didn't help. As Brian said, a junkyard may be one of your best bets. :sly:
GSS123
04-19-2004, 11:07 AM
Purchase some JB weld from an Auto parts store. Its an epoxy that will join about anything together or seal a crack. I've repaired several non pressurized tanks that had leaks. Worth the $6 just to have around to glue, weld or repair other house hold items. Try it and let us know if it worked or not.
Brian R.
04-19-2004, 02:48 PM
Although it may be worth a try, I don't think the epoxy has a chance of fixing it. Hot, flexing, pressure, ethylene glycol, dirty, and the normal tendency for crack-propogation all add up to "no chance".
GSS123
04-19-2004, 02:55 PM
Brian R. may be correct? He along with several others offer some of the best advice on this forum. But for the total dollars invested vs. Radiator replacement I would give it try. Clean the area off real good and follow mixing instructions on the JB weld package.
Let us know what happens.
Brian R.
04-19-2004, 03:43 PM
Sure, can't hurt anything to try. Don't go on a long trip with it. :)
I'll edit the above with the possibility of it working if it is on a flat area and you can glue a plastic patch over the top. If this is the case, drill a couple of holes at the end of the crack (make sure it's the end of the crack) so that the crack cannot propogate as easily. After you glue the patch over the crack with alot of overlap, let it dry well before you fill it and pressurize it.
I didn't expect that it was on a flat area since these things crack everywhere except on a flat area, but if it was hit by something, it is possible...
smallbaby
06-05-2004, 10:33 PM
use epoxy it work great!!! my camry radiator broke on the top 3-4 inch. long . first clean and sand it, wash it nice then mix the epoxy and let it dry at lease 24 hr. it the normal temp. The radiator don't just crack, it much be something that cost it. I recommend you the check you termostat, it problebly not function will that why it had that much pressure to crack you radiator. goodluck.
Brian R.
06-05-2004, 11:05 PM
YMMV
Bossman
06-12-2004, 04:07 AM
Brian R,
OK, I haven't figured it out yet so, please, tell me; what does "YMMV" mean? Thanks. :)
Brian R.
06-13-2004, 02:42 PM
Your Mileage May Vary. Meaning that I have my doubts that the fix will work, but it might. Never say never.
Bossman
06-17-2004, 04:30 AM
OH, OK, thanks Brian, I have to admit that was a tough one for me! I better brush up on my forum terminology. :banghead:
gator86
06-18-2004, 08:46 PM
i'm sure this is too late to help jstrummer, but maybe it will help others.
i used the jb weld to repair a crack in the same place on the top of the radiator of my 94 camry.
There is an area across the top of the radiator where it gets wider, going from the top of the radioator to the ground. that is where my crack developed, and i would imagine this has happened to many of these same radiators. I think it was caused by age, and the heat more than anything else. I , wire brushed and sanded it, cleaned it good, and applied a liberal amount of JB weld over it. it has lasted like this for over a year.
i know some of you won't believe this, but i helped my dad repair a cracked head in a b-61 mack truck with JB and it operated for over 100,000 more miles with this fix.
gelcol
06-23-2004, 10:19 PM
samething happeneds to my radiator and the radiator master told me to get the metal ones and 2 rows of radiator instead of the original ones has one row underneath this makes the calcium deposites build ups and can't circulate the hot water & coolant.
Bmaintz
06-24-2004, 09:51 AM
I bought a new radiator on Ebay for $65 plus S/H...
My radiator developed a leak on the seal for the top plastic tank, tried to push in the bulged out seal but didn't work... I used JB Weld on a cracked block on a Mercury in/outboard (Chevy block) & it worked great... Bob
Bmaintz
06-24-2004, 09:56 AM
Just a note..... JB Weld does have a "Kwik" set....
Bonds in 4 minutes, I have used it & sets up quickly...
I would still let your repair set-up over night... I would also clean with rubbing alchol with a stiff brush so it gets down into the crack... Bob
Google
Web AF
