Touch up paint job.
Google
Web AF
mrtwo
04-16-2004, 08:55 AM
I recently did some touch up paint job on my camry. I used the 3M sander pen which is made from fiberglass to remove the rust. No matter how hard I tried, I just can not remove the bottom layer of rust. Same thing on the corolla. It is kind of like the weathering steel, which will develop a protection layer after several years to prevent further corrosion. My question is Can i just leave the layer there or i have to remove it? If i have to, what can i use to remove it? Any experience?
yotatechie04
04-18-2004, 08:44 PM
I've had similiar problems with my Camry when touching up. I attempted to use the fiberglass pen as well, and did good for so long until it got to the bottom. I think that if you do decide to go ahead and touch it up from that layer it will eventually show through or bubble up. I ended up using a really fine grit sandpaper to remove the remaining rust, which if used very carefully, it will work effectively. Other than that, if you decide to use a rough sandpaper, you'll more than likely have to repaint the whole panel.
mrtwo
04-18-2004, 09:34 PM
What is the degree of the sandpaper you used? Do u paint on the bare metal directly?
csaxon
04-19-2004, 10:55 AM
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=1122&itemType=PRODUCT&iMainCat=379&iSubCat=380&iProductID=1122
mrtwo
04-19-2004, 11:11 AM
csaxon, Did u use it? how did it work?
yotatechie04
04-19-2004, 02:58 PM
You don't paint the bare metal directly, if you use a touch-up can with the little brush, you can buy a kit, which you can primer the metal first.
yotatechie04
04-19-2004, 03:04 PM
I used 200 grit...slowly working my way higher up to about 300 until the metal is prepped for primer.
csaxon
04-20-2004, 11:11 AM
mrtwo it's used by a lot of professional paint/body shops. It was used on my old Benz at Stewarts Autobody in Memphis and I watched detailer I know here in Cedar Rapids using it on a BMW restoration. That line of products is easy and safe to use..it really gets the rust out without harming the paint. 3M also makes a similar product but it was very agressive and caustic and expensive. I would suggest it for complete part dipping only, not spot rust.
Google
Web AF
