94 Jetta possible electrical problem help!Vduber 04-15-2004, 12:32 PM ok i have a 94 jetta that has been running realy strange and now will not start. befor when it was still running the rpms would jump up and down while sitting at a stoplight or whatnot. it died on me yesterday when i was driving...i went into 2nd gear and the exhaust started sputtering like it wasnt firing on all cylinders and now wont start. when i attemp to start it, it cranks but wont fire and as soon as i let of the key it backfires......someone help Vduber 04-15-2004, 12:54 PM some other info on my jetta....engine 2.0 4 cylinder...tranny 5 speed....has around 150,000 mile on it.....aftermarket exhaust and intake Vduber 04-15-2004, 02:45 PM never mind on the not starting problem...it turned out to be the distributor rotor....part of the inside tab that slips into the noch on the shaft broke so the rotor was not spinning. danewera 01-23-2005, 06:50 PM HELP... This Is my situation... I just bought a brand new battery for my 94 jetta because the old one died. When I hooked toe battery up the fan started spinning. It wont stop, So now i have to leave one terminal unplugged so it wont kill this new battery. PLease help. i REALLY APPRECIATE efforts and tips. boschmann 01-24-2005, 12:52 PM Can you see if anyone had messed with the fan wiring? If not, then unplug the switch on the radiator & see if it stops, it may be stuck on. danewera 02-20-2005, 08:14 PM i have lots of questions about my car...so before i start annyoying you automotive forum regulars/experts, you can let me know if theres a better place i can get tips(for free). 1 By the coolant dome thing, theres are slots for 2 fuses, whats that for? my car only has one fuse, on the left side. 2 when the cars starts to heat up it starts makin a clicking sound from the engine. 3 can radiator cables be replaced. 4 is the electric sunroof designed to slide back or just pivot open enought to leave a 1-2 inch slit? boschmann 03-09-2005, 07:01 PM 1) I believe one's for the cooling fan (A/C), the other I can't remember, but I've seen alot of cars w/o it. 2) Could be lifter noise, what quality & weight oil are you using? 3) I don't know what a radiator cable is. 4) Factory electric sunroofs slide all the way back. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
