Removing the radio on 97 stratus.
sfm
04-15-2004, 11:32 AM
I have a 97 Stratus with a tape player in it. My daughter has a 97 Sebring without a tape player. I want to switch the two radios. Can anybody tell me how to remove the face plate and the radios in these cars. Thanks
thejuice
04-25-2004, 01:45 PM
sfm, i figured it out. Get a screw driver and drive it behind the face plate on the left side and use the leverage to pop it off. The thing has 4 clips on it in each of the four corners.
Goodluck
canker4077
08-17-2007, 11:30 PM
on my stratus I took off the bezel and then just took out two bolts it was as easy as that
dsramprat
08-18-2007, 01:37 AM
Yes it is that easy, Pry off the bezel, that plastic piece surrounding the radio and the climate control module. Remove the two 10mm bolts, one on either side of the radio, pull out the radio and disconnect the two electrical connectors, and the antenna cable. Your done.
