type r intake manifold idle problem please help!!
96b16acoupe
04-14-2004, 08:10 PM
i was wondsering if anybody had expierince puting on a type r mainfold to a b16a head?? i recently put one on my car but it idles very high (2500 rpm). i know i need to adjust my tps but would that make it idle that high? it has been tested for manifold leaks and it is leak free do i need to re-adjust the idle on it? i replaced the iac valve since the old one didnt fit, but it was used. someone please help me with this mess!! :uhoh: :banghead:
whtteg
04-14-2004, 09:40 PM
Does the idle surge any?
96b16acoupe
04-15-2004, 12:41 AM
it did at first then i checked the the tps and now its just idling at 2500 rpm iknow i need to re-adjust the tsp though or need a new one.
Buggzy
04-16-2004, 09:49 PM
try readjusting your idle first if this doesn't carrect the problem then check your IAC
BrokenLimits
04-18-2004, 10:07 AM
Did you screw in the Idle Screw? Screwing it in lowers the idle loosening it raises it.
YellowITR479
04-21-2004, 01:36 PM
My car did that before, My problem was the hose going into the firewall side of the intake manifold was loose. It caused the car to idle high and surge.
