1998 Camry rear side marker light bulb replace?tondown 04-12-2004, 12:08 PM The right rear side marker light is out but I cannot figure out how to replace it and the Toyota car manual diagram is not correct. It shows three bulbs but I took the right light out and there are only two bulbs - signal light and taill light. Thanks. Joe W 04-12-2004, 07:15 PM This is accessed from the inside the trunk.Pull away the liner and there is access to the bulbs. gator2764 04-14-2004, 05:12 AM The right rear side marker light is out but I cannot figure out how to replace it and the Toyota car manual diagram is not correct. It shows three bulbs but I took the right light out and there are only two bulbs - signal light and taill light. Thanks. You might want to just replace all of the corner marker lights. My 95 had one go out a few years back and right after I relaced that one the others started to fail as well. 1998CamryLE2.2 04-27-2004, 08:40 PM The right rear side marker light is out but I cannot figure out how to replace it and the Toyota car manual diagram is not correct. It shows three bulbs but I took the right light out and there are only two bulbs - signal light and taill light. Thanks. Remove the panel inside the trunk. the side marker is off to the side. I got mine out with no problem but getting it back in was tough. I'm sure that doing it at night was part of the problem. If you can see the rear lights, you should be able to see the side marker light as well. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
