93 Celica GT Loss of power
junkie007
04-08-2004, 02:51 PM
It has about 135K miles on it. Its acceleration is not proportional to the pressure on gas pedal. I can sense a loss of power especially at lower speeds. When I drive around 60 and above I do not notice much. I can also sense its power in spurts, when I floor the gas pedal especially in lower gears i.e. 1,2 and 3. I recently replaced the Clutch and CV joints on this car. Other than this, it has been a great car. I would really appreciate your advice.
jimbobillybob
04-10-2004, 08:31 AM
double check all the electical and vacumn connections real good ,if someone else replaced your clutch they might have hooked something up wrong or bent some pins
junkie007
04-12-2004, 01:21 PM
Thanks jimbobillybob.
I noticed that #3 Cable to the sparkPlug keeps disconnecting. Not sure if there is any bent pin holder.. !!
Joshyak
04-14-2004, 01:14 PM
Id check the throttle position sensor. Hook an ohmeter up to the connector and make sure the resistance is proportional to the movement of the butterfly valve. Id also get a new set of plug wires if they're not attaching right ($40 bucks at autozone) maybe even a new distributor cap and rotor ($20 bucks autozone.) Check your spark plugs and make sure they arent bridged with carbon. Good luck
