96 jetta trek
Google
Web AF
wnatas
04-06-2004, 12:12 PM
can someone tell me where is locate the fuel filter in a 96 jetta , and also I need to change the brake pads (turn rotors?) .
I have never touched a Jetta before, is there anything special about the brake system that I need to be aware of?
Thanks in advance!
:banghead: :banghead:
Tacuvito
04-06-2004, 03:33 PM
Fuel filter is located at the rear of the car on the passenger side, immediately after the gas tank.
The break system I need to know what type of model GLX, GLS, GL, etc. since there is variety of breaking systems. If you have worked on brakes b-fore then you should have no problem, the only thing is that pads are a bit expensive is your car uses the type of pad that has a sensor in it. Good Luck.
Tacuvito.
wnatas
04-07-2004, 05:35 AM
my car is a jetta trek 2.0 you think that is hard to change the fuel filter
Google
Web AF
