Car died after driving and will not restart.Cjz89civic 04-06-2004, 05:12 AM Ok I have a 90 civic with a 95 d16z6 in it. It is Obd1 now, properly wired. My question is has anybody had a problem diving down the road and the car just die like it is out of gas. I checked to see is if there was fuel pressure and there is, nice hot spark, no codes. If anybody can help It would be great. Other question do 92+ civic also have the main relay problem and could this be the problem? 96Civ 04-06-2004, 06:37 PM Did you remember to put oil in the engine?? :boink: GScivic7 04-06-2004, 06:59 PM does it crank at all? If it doesn't it could be your battery or alt. Beastiek2 04-06-2004, 07:17 PM yea first try battery go to any local gas station and have them check the volts on it, its most likely the problem, if it were the alt i dont think it would start at all, my stang needed a new alt just to start up Cjz89civic 04-06-2004, 11:25 PM Got it thanks guys. It ended up being the timing belt slipped 6 teeth. Dont know how that happened new belt new tentioner oh well reset it retightened and Im off and running again. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
