Help No power to headlights.Bill8Bud 04-03-2004, 11:41 PM I have run into an issue with my 2000 Dodge Durango. My regular headlights will not turn on. I have checked all of the fuses in the fuse panel, plus I have checked a few extra fuses I found under the dash. My high beams work :eek7: , but when I turn my headlights on I get no power to the socket the Halogen bulbs plug into. Any Idea on what I may be over looking? 1zzy 05-14-2004, 08:17 AM it is most likely the headlight switch assembly. Think I paid close to $70 for mine and had to have the dealership change it due to an anti-theft torx head bolt with a center pin used to secure it. seniorbigs 05-28-2004, 08:10 PM Did you get it fixed. I've seen wires get pulled out of the dimmer switch harness. Try tilting the wheel all the way up and down and see if the lows come on while doing this. Sometimes there is not enough slack in the wire harness to allow slack when tilting the wheel. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
