81,000 on original brake pads, rotors are warped too.
lilyorkie
03-30-2004, 10:38 PM
who sells the cheapest drilled or slotted or both for a 1999 silverado 4wd z71, I figure I got my use out of these.
desertmike1
03-31-2004, 07:41 AM
I've read somewere that stock rotors are a big ticket item, can't emagine after market (if) available.
Turn your rotors, clean up the calipers, and try a set of NAPA Cermix brake pads, these are hands down some of the best brake pads you can buy, and only 10-20 bucks over stock.
I'll never install wadded up metal (Metalic) brake linings again.
My two cents worth!
-Mike
jeverett
03-31-2004, 08:37 AM
FYI.. This jsut happened to me 2 days ago. After you replace your rear brake pads, be SURE TO TIGHTEN the caliper bolts to the recommended torque, or either use a slight amount of lock-tite. The bolts on my right rear caliper fell out on a dirt road about 10 miles from town and the caliper cut a nice groove on the inside of the rim.
