Have fire and compression; need fuelladymech62 03-29-2004, 03:36 AM A friend has a little four cylinder. Got power to the injectors and have had the injectors out and cleaned. Still not getting fuel to the last two cylinders. What next? I'm :banghead: ! amac209 03-29-2004, 06:24 AM are the injectors getting ground pulses from the computer?? what happens if you swap the injectors? a noid light is the easiest way to determine if the circuits working correctly. also check the fuel pressure, it might me on the borderline. if the injectors aren't getting pulsed check for damaged wiring or possible a bad computer. good luck ladymech62 03-31-2004, 01:14 AM Eureka! they're checking for a bad wire and we're trying to line up someone to check the compy . . . vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
