Rocker arms initial install; 300 inch 6 cylJimWD 03-28-2004, 07:36 AM Posting for a family member doing a head replacement on a 300 (1984 model truck). What is the accepted - recommended method of installing rocker arms? Do we use a torque value or a specific number of turns? Engine was last running less than a week ago, so the lifters should not be dry. Thanks in advance for any guidance. 97chevyman 03-28-2004, 10:26 AM Well, here is the way i did it on my 78 300 I6. Get a second nut for each rocker arm, so you can make them adjustable. Buy a feeler gauge and adjust the valve to have .010 of clearance, then put the second nut on there and it will hold it in place. ModMech 03-28-2004, 11:16 AM Just torque them down. I *think* the spec is like 25 ft-lbs. Slowly is best so the oil can bleed out. JimWD 03-28-2004, 08:33 PM Thanks for the help, guys; much appreciated. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
