gtp stallingsurf2 03-27-2004, 05:12 PM :banghead: :banghead: i have a 98 gtp that stalls at times,with 73,000 on the clock..there is a new crank position sensor,a new module for the coil packs,a new computer.the car will run good for about 3-5 days and then it just stalls, driving at hi-way speeds,sitting at a stop light..there is no code,no warning at all.i had it hooked up to a scanner for 2.5 hrs,everything is normal.all the grounds are ok,all the connections are ok,the fuel system is fine....i am at my wits end!! :banghead: :banghead: i hate to get rid of it because i can not drive a unreliable car...maybe somebody can help.........thanks :banghead: :banghead: :banghead: JoeJoe231455 03-27-2004, 06:03 PM just a quick thought...have you checked the battery cable connections at the battery? Sometimes corrosion on the terminals can cause that. Also, make sure that the positive lead bolted on to that big fuse box in the engine bay is not touching the rubber shields. That can do it too... GTPCatz 03-27-2004, 10:57 PM when you replaced the CPS did you get a case learn done? Still sounds like a bad CPS... surf2 03-28-2004, 06:45 AM all the batt connections ok,put in a new cps(another one),the computer was flashed at the dealer, 00 GTP 03-29-2004, 10:11 AM Sounds like same problem as mine. See 2000 GTP stalls out. Is this what you are experiencing? kilroypr 03-29-2004, 08:00 PM http://www.automotiveforums.com/vbulletin/showthread.php?t=206713 Make sure that the right amoung of fuel and air are reaching at the combustion chamber. surf2 03-29-2004, 08:28 PM im reaching out here,could the tb screen removal cause this..i though i read something on hear about the screen throwing a code or something.. GTPCatz 03-29-2004, 08:39 PM im reaching out here,could the tb screen removal cause this..i though i read something on hear about the screen throwing a code or something.. Put it back and find out! I have heard that earlier models have had a problem with the removal of this screen.... kilroypr 03-29-2004, 08:44 PM I have heard that hesitation could be caused by the screen removal but in my case the car idles better now. Mine is a 98 GTP vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
