headlights quit 94 cherokeebikechuck 03-24-2004, 12:52 PM last night headlights wouldn't work when engine started. They would operate until engine was started , then nothing. While engine was running the dimmer switch would make them flash in the mid position.Tail lights, dash lights normal. Fuses look good. I suspect headlight delay module , you know the one that keeps the headlight on for a short time after shutdown. Where is this guy located and approx cost. thanks nukepower 03-24-2004, 12:58 PM first of i have had a similar problem with my jeep. believe it or not i was low on headlight fluid. just make sure you use high beam approved headlight fluid. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
