Need Help.........
Google
Web AF
1990 Chevy Corsica
03-19-2004, 11:44 PM
I have a 1990 Chevy Corsica, Auto, 4Cyl. I am having a stalling Problem, If I drive my car for more than 20 minutes at a time it dies if I Stop for any reason and when I get it started back up and put it in any gear it dies again. can you help?
Also yesterday, my car died I mean completly dead battery and all then all of a sudden it started back up, weird I know, i got home ok then went to start it up again and it was dead, replaced the battery and it now runs but it runs crapier than before, what happen?
PLEASE HELP IF YOU CAN.. THANK YOU.
Jennifer
brooster
03-20-2004, 12:28 AM
Well, now you have a new battery. Have someone, possibly Advance or Autozone check the charging system (alternator), because if it's not good, you'll just end up with a dead battery again.
Make sure the battery cable ends were cleaned good when the battery was replaced.
Now, barring any other problems you may have, go through the idle relearn procedure.
Since I don't have the specifics for your car, try this. Set the parking brake (I hope the brake works). Start the car and place it in drive. Let the engine run with the trans in drive until the cooling fan comes on. Turn off the engine, wait 30 seconds and repeat the previous steps. Do not leave the car unattended while performing this task.
If the idle relearn does not work, you may have problems elsewhere.
Some things to consider are dirty throttle body and idle air control motor. Clogged fuel filter or weak fuel pump. Does the check engine light come on while you're driving? Are the spark plugs in good shape?
Start with the basics I've given, and let's see where to go from there.
1990 Chevy Corsica
04-06-2004, 07:12 PM
Thanks for the info. I put a new battery in and it's been running fine. Still stalls out when I drive it for more than 15-20mins it will start right back up but after I put it in Drive it dies again. :(
cwpj12
04-07-2004, 08:45 AM
I'm having the same problem with my corisca. Did you ever fix the problem?
Google
Web AF
