Where is a/c fuse located for 90 jeep cherokee laredojhredd 03-19-2004, 04:26 PM Hi, can someone please tell me where the fuse for the a/c is located on a 1990 jeep cherokee laredo? I don't see it marked in the fuse box under the dash. I see 2 30 amp silver relays in the fuse panel but they are not marked. I switched them in case one of them was bad but my a/c still will not kick in. It has pleanty of freon and when i manually jump volts to the a/c cluth outside it kicks in and the a/c gets cold. But without me doing this there is no power going to it. Thanks so much, James Dale Aeppli 03-19-2004, 08:04 PM Hi, can someone please tell me where the fuse for the a/c is located on a 1990 jeep cherokee laredo? I don't see it marked in the fuse box under the dash. I see 2 30 amp silver relays in the fuse panel but they are not marked. I switched them in case one of them was bad but my a/c still will not kick in. It has pleanty of freon and when i manually jump volts to the a/c cluth outside it kicks in and the a/c gets cold. But without me doing this there is no power going to it. Thanks so much, James :headshake HI, right off hand does your jeep have a power distribution control box mounted right behind the battery. its a black box with relays & fuses in it. if so email me directly & i'll send you a diagram showing all the relays & fuses & what they are for. i can't email them from files thru forum. email---jeepman600@aol.com DALE jhredd 03-27-2004, 01:19 PM Thanks to you all. I found it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
