Automatic Windows??
tafnuef
03-17-2004, 11:23 PM
Can anyone give me an Idea as to why my windows have quit working? my door locks work fine but my automatic windows have stopped working. On any of my switches? I have changed my fuse so that theory is out??? HELP Warm weather is approaching...
Caribbean ZJ
03-19-2004, 08:57 AM
What year is your jeep. Is it all the windows.
Vindaloo
05-05-2004, 07:37 PM
Hi did you ever get this fixed as I have the same problem and I just went and spent $120 on the drivers main door switch as I was 100% sure it was it bt even though I have power on the loom I still have no up down on my power windows on all doors. Please help if you can.
Thanks
Bally
gibsonl4e
12-19-2005, 07:44 PM
I have a 1995 jeep grand cherokee and am having the same problem. checked fuses and replaced anyways. I was in a haynes manual and it was saying something about a relay but I couldn't find anything in the electrical diagram to indicate this. what's next any one have any ideas
dksob81
12-19-2005, 08:18 PM
Have all the windows stopped working?
Have you tried the Passengerside door switch to see if it still operates the passneger side window?
Check the wiring in the door jam in between the Drivers door and the body these wires get fatigued and break. Chances are you have a couple broken wires.
teemsta
12-19-2005, 11:02 PM
had a problem with my window controls on my 94 jeep. ended up being crackes/rotted wires between the door jam and dash where you open the door. pulled rubber protector back and saw wires dried up and cracked or seoereated. try looking in that area.
Dins
12-20-2005, 11:44 AM
I've been having the same problem with my Jeep, I havn't yet figured out the problem but I found out that if I continually lock and unlock the doors while holding down the window switch my windows will work. If you have any luck figuring out the problem please let me know. Thanks
