pass key4onFloor 03-17-2004, 09:56 PM what is the pass-key decoder module for? also, what does the elect. spark controll module look like on a 1990 camaro RS 305tbi 89IROC&RS 03-17-2004, 11:51 PM pass-key is anti theft. so that only a key with the correct resistor will alow the engine to crank and fire. electronic spark control module is in the distributor. where the two plugs connect. 4onFloor 03-18-2004, 01:09 PM is the pass key module for use with security upgrade or something, cause this camaro was stollen and they broke the steering column so they could push the linkage that moves the slide switch to the start position. also, i have a white plastic module under the dash, kind of a white clear plastic with 2 connectors going to it. it's about 3 1/2 inches wide, 1/2 inch thick. what is it? 89IROC&RS 03-18-2004, 09:18 PM passkey is the security, its the antitheft device its self. i find it hard to beleive that they got it started without a proper resistor to insert into it. it wouldnt start. as far as the other module, ill have to look tomorrow. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
