clueless question
Google
Web AF
trixie128
03-16-2004, 12:24 PM
I feel stupid asking this question because it is totally ignorant, but I guess I won't have to ask it again if I find the answer. How do I know what kind of fuse to use to replace one in my 2000 Camaro? I know it is a blade type and 20 amp, but what does the "ATC" or "FT" mean? Which one do I pick? Thanks for your time.
T
DaMoNe6969
03-16-2004, 02:10 PM
Well, I dont think ive ever heard of an FT type blade fuse.. You should need an ATC 20amp mini-blade fuse..
trixie128
03-16-2004, 03:09 PM
Thanks, your right. I meant the difference btwn MAXI,ATC,&ATM but was typing off the top of my head instead of looking at the package and still don't know what they stand for. BUT!!!, the problem wasn't even the fuse! My turn signal is not flashing correctly, but it's not indicating that a bulb is out. It's flashing erratically and out of time. So, basically NOT WORKING. Do you have any ideas that might help? Thanks for the reply!
T
89IROC&RS
03-16-2004, 07:11 PM
could be two things, the flasher its self is having trouble, or the multifunction switch inside the steering coulumn.
trixie128
03-17-2004, 11:54 AM
How do I get to the flasher? Is it in a fuse box? or under the hood? I want to fix the problem, but I don't really know who to ask. I can't pay a diagnostic fee for a signal problem...I'll never be able to save enough $ to upgrade things if I can't learn to do the small things myself. Ugh! Frustration! Thanks so much for your help :-)
DaMoNe6969
03-17-2004, 07:45 PM
Is it flashing eratically both directions? or just right, or left? What about your hazards?
DaMoNe6969
03-17-2004, 07:50 PM
If i remember correctly, if you take off the panel under the steering wheel (right above your shins) there should be a flasher on either side of the steering wheel???
Hope that helps
89IROC&RS
03-17-2004, 11:49 PM
uh....... never had to change mine, so ill have to take a look and get back to ya, not sure where it is off the top of my head, its definately behind the dash somewhere, either at the bottom of the steering column or where the fuses are, im not sure.
trixie128
03-18-2004, 10:32 AM
You guys are the BEST! Thank you SOoooo much! I will look today when I get off work.
T
trixie128
03-24-2004, 10:51 AM
OK, so I found it, and changed it, and now it works fine! It was easier than a fog light. Thanks for your help everyone.
T
Google
Web AF
