tow relay problem 95 grand cherokee
Harryw
03-15-2004, 09:37 AM
My 95 Grand Cherokee has a towing light problem. All of the connector sockets are hot even when the lights/ignition are off. When the trailer is plugged in, the stop lights are on constantly on. It sounds like a relay problem, where is the towing relay of this Jeep? Is there maybe more problems that I'm not thinking about?
Harry Willems
Dale Aeppli
03-15-2004, 06:45 PM
Harry Willems
Sounds like you have problems in you trailer light connector, there are relays, i never heard of a towing relay. if this happens when you hook up your trailer then the trouble is is your trailer wiring. most wiring problems are ground related, check youwiring connectors. dale
jeepman600@aol.com :banghead:
Biohertz
06-21-2004, 04:30 PM
I had the same crap going on in my '94 JGC! One night I walked out into the garage, and my parking lights were on! Ever since I bought my jeep (used) the trailer lights never worked, so I would just pull the fuse out, which kept my radio antenna up. But everything else was cool. After a while I pluged the fuse back in, and it stoped, however every once in a while it screws up again.... I do not know why
