97 4dr/2.2 Cavalier Oil Light @ Low RPMskabbage 03-14-2004, 03:37 PM my 97 4dr/2.2 Cavalier's oil light comes on at about 800-900 RPMs and then goes off when above that. So basically i just see it come on at stop lights after the car has warmed up. I brought it to a shop that i trust because it was having additional problems as well, and after having the engine flushed and the timing chain/gears and the valve cover replaced the mysterious oil light still is coming on at 800-900 RPMs. We tried setting the idle a little higher but that didn't work. Any ideas? kabbage 03-15-2004, 01:05 AM could it be the oil pump? 98cavvykid 03-15-2004, 04:43 PM Try checking all your oil/fuel levels... Oil pumps usually cause more serious problems such as not starting/turning over, but its still possible, wouldn't hurt to have it checked. My 98 used to have the same problem but it mysteriously stopped one day and hasn't occured again. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
