do 1.8L gt injectors work on 1.9L lx intake???Pompi 03-14-2004, 01:10 PM I have a 1995 ford escort hatch, 1.9L and i want to replace myfuel injectors cause its slowing my car and it makes noise, anyways i was wondering if the fuel injectors froma 1.8l GT would fit in my intake (if there the same injectors)....... Is there a diameter difference or seal difference of anything or anything like that??????? please anyone who knows.... A.S.A.P THANKS POMPI jeffescortlx 03-14-2004, 07:43 PM Your injectors are not "slowing your car", and what you hear is the valve train noise not your injector's. And no, the GT injectors are not compatible to the lx. 92EscrtPmp 09-30-2004, 12:48 AM No!!!! The injectors don't match. One is a EFI motor, and the other is a SEFI motor. It would throw the fuel to the motor in the wrong sequence, or for that matter, the EFI's flood the Cylinders and the SEFI's use way less. Then the bolt pattern is different. The only 1.8's I've seen are DOHC motors. 1.9's are SOHC Inline. and to top it off, the noise you hear is probably: Bad timing, loose lifters, or a clogged injector. Don't try jerry-rigging something together, please? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
