Another Problem...when will it end!
KSAV8TOR
03-13-2004, 04:37 PM
I got my braking problem fixed,the one where the caliper was locked and pulled to the left side,it was a brake line hose that caused that one.
NOW..when i put the wheel back on i noticed that i could wobble the wheel side to side,had a freind tell me it's the Idler arm,this truck only has 42000 miles on it and i bought it new in 1991...should i be having these types of problems at this mileage?
If indeed it is the Idler Arm..how do i replace it?
My truck is a 1991 Silverado 2WD.
Thanks for all the suggestions!
pind
03-14-2004, 10:44 AM
on the 90 and 91 2wd trucks, this was an issue. They are nice trucks, but from my experience with them, if you want the problems to end, buy a horse.
These were somewhat transitional years for chevy trucks, and there were a lot of problems.
Alternators failing repeatedly due to bearings, idler arms, lower ball joints, bad paint/primer, instrument panel issues just to name a few.
If you choose to stick with the truck, good luck with it, they are great after you work the bugs out.
