gm code site
two50twostroke
03-12-2004, 10:30 AM
here is a link for a gm site i found on the net hope it works for you www.wrenchman.freeservers.com/fordsux/gm.htm
Flatrater
03-14-2004, 04:03 PM
That will work for anything older than an 1995 car or truck that is OBD!
Here is an OBD2 list for all modules!!!
Diagnostic Trouble Code (DTC) List - Vehicle
DTC
Descriptor
DTC B0012, B0013, B0014, B0016, B0017, or B0018
Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit
DTC B0022, B0024, B0026, B0042, B0043, or B0044
Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit
DTC B0028, B0029, or B0030
Right Front/Driver Side Deployment Loop Circuit
DTC B0040, B0041, or B0045
Left Front/Driver Side Deployment Loop Circuit
DTC B0051
Deployment Commanded
DTC B0053
Deployment Commanded with Loop Malfunctions Present
DTC B0077, B0078, B0079, B0080, B0081, or B0082
Left Front/Driver Side Impact Sensor (SIS) Circuit
DTC B0100, B0101, or B0102
Electronic Front End Sensor 1 Circuit
DTC B0184 or B0189
Solar Load Sensor Circuit
DTC B0490
Passenger Temperature Control Cooler/Warmer Switch Circuit Range
DTC B1000
ECU Malfunction
DTC B1001
Option Configuration Error
DTC B1004
Keep Alive Memory (KAM)
DTC B1007
EEPROM Write Error
DTC B1009
EEPROM Checksum Error
DTC B1010
Calibration ROM Checksum Error
DTC B1259
Antenna Ground Circuit
DTC B1327
Device Power Circuit Low
DTC B1336
Device Power 3 Circuit Range/Performance
DTC B1390
Device Voltage Reference Input CKT Malf
DTC B1420
Device Voltage
DTC B1422
Device Power Moding Malfunction
DTC B1513
Charging System Volts Low
DTC B1514
Charging System Volts High
DTC B1562, B1567, B1572, or B1577
Mirror Switch Circuit
DTC B1582, B1583, B1592, B1593, B1612, B1613, B1622, or B1623
Mirror Position Sensor Circuit
DTC B1658
EPROM Read Write Error
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, B1820, B1830, B1835, B1840, B1845, B1940, or B1945
Power Seat Switch Circuit
DTC B1780
Theft Lock Enabled
DTC B1825, B1850, B1860, B2355, B2365, or B2375
Power Seat Position Sensor Circuit
DTC B1826, B1851, B1861, B2356, B2366, or B2376
Power Seat Sensor Circuit Range Performance
DTC B2455
Cellular Phone Microphone Circuit
DTC B2470
Cellular Phone Antenna Circuit
DTC B2476
Cellular Phone Select Service Switch Malfunction
DTC B2482
Cellular Phone Select Service Switch Range/Performance
DTC B2483 or B2484
Global Positioning System (GPS) Antenna Circuit
DTC B2556
Interior Lamp Rheostat Circuit Range
DTC B2627
Pass Compartment Dimming #2 Circuit Low
DTC B2628
Pass Compartment Dimming #2 Circuit High
DTC B2641
Delayed Exterior Lighting Ctrl CKT Range
DTC B2642
Delayed Exterior Lighting Ctrl CKT Low
DTC B2643
Delayed Exterior Lighting Ctrl CKT High
DTC B2646
Ambient Light Sensor Circuit Range
DTC B2647
Ambient Light Sensor Circuit Low
DTC B2648
Ambient Light Sensor Circuit High
DTC B2757, B2762, B2767, or B2772
Memory Switch Circuit
DTC B2805
Steering Whl Controls HVAC Sw CKT Malf
DTC B2810
Steering Whl Ctrl Entertainment CKT Malf
DTC B2823-B3574
Driver Information Center (DIC) Switch Circuit
DTC B2960
Invalid Coded Key Present
DTC B3031
Key Decoder Device in Assem Learn Mode
DTC B3055
Key Not Present
DTC B3109
Keyless Entry Transmitter Low Battery
DTC B3142, B3147, B3152, or B3157
Door Lock Switch Circuit
DTC B3172, B3177, B3182, B3187, B3192, B3197, B3282, B3287, or B3292
Window Switch Circuit
DTC B3377, B3382, B3387, B3392, B3397, B3452, B3457, B3462, B3467, B3472, B3477, B3482, B3517, or B3522
Master Window Switch Circuit
DTC B3527
Window Lockout Switch Circuit Low
DTC C0625
Level Control Suspension Sensor Malfunction
DTC C0628
Level Control Position Sensor Circuit High
DTC C0660
Level Control Exhaust Valve Circuit Malfunction
DTC C0663
Level Control Exhaust Valve Circuit High
DTC C1211
ABS Indicator Lamp Circuit Malfunction
DTC C1214
System Relay Contact or Coil Circuit Open
DTC C1217
Pump Motor Shorted to Ground
DTC C1218
Pump Motor Circuit Shorted to Voltage or Motor Ground Open
DTC C1221-C1235
Wheel Speed Sensor Circuit
DTC C1236
Low System Supply Voltage
DTC C1237
High System Supply Voltage
DTC C1238
Brake Thermal Model Exceeded
DTC C1242 or C1243
Pump Motor Circuit
DTC C1245
Low Tire Pressure Detected
DTC C1248
EBCM Turned the Red Brake Warning Indicator On
DTC C1254
Abnormal Shutdown Detected
DTC C1255 or C1256
ECU Malfunction
DTC C1261-C1274
EBCM Internal Solenoid Circuit
DTC C1276, P1644, or P1689
Delivered Torque Circuit
DTC C1277 or P1571
Powertrain Indicated Traction Control Malfunction
DTC C1278
TCS Temporarily Inhibited By PCM
DTC C1281, C1283, or C1286
VSES Sensors Uncorrected
DTC C1282
Yaw Rate Sensor Bias Circuit Malfunction
DTC C1284 or C1285
Lateral Accelerometer Circuit
DTC C1287 or C1288
Steering Position Sensor Circuit
DTC C1291 or C1293
Brake Switch Circuit
DTC C1294
Brake Lamp Switch Circuit Always Active
DTC C1295
Brake Lamp Switch Circuit Open
DTC P0030
HO2S Heater Control Circuit Sensor 1
DTC P0036
HO2S Heater Control Circuit Sensor 2
DTC P0101
Mass Air Flow (MAF) Sensor Performance
DTC P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0116
Engine Coolant Temperature (ECT) Sensor Performance
DTC P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0121
Throttle Position (TP) Sensor Performance
DTC P0122
Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123
Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125
Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0130
HO2S Circuit Closed Loop (CL) Performance Sensor 1
DTC P0131
HO2S Circuit Low Voltage Sensor 1
DTC P0132
HO2S Circuit High Voltage Sensor 1
DTC P0133
HO2S Slow Response Sensor 1
DTC P0134
HO2S Circuit Insufficient Activity Sensor 1
DTC P0135
HO2S Heater Performance Sensor 1
DTC P0136
HO2S Sensor Circuit Sensor 2
DTC P0137
HO2S Circuit Low Voltage Sensor 2
DTC P0138
HO2S Circuit High Voltage Sensor 2
DTC P0140
HO2S Circuit Insufficient Activity Sensor 2
DTC P0141
HO2S Heater Performance Sensor 2
DTC P0171
Fuel Trim System Lean
DTC P0172
Fuel Trim System Rich
DTC P0201-P0206
Injector Control Circuit
DTC P0218
Transmission Fluid Overtemperature
DTC P0230
Fuel Pump Relay Control Circuit
DTC P0300
Engine Misfire Detected
DTC P0315
Crankshaft Position System Variation Not Learned
DTC P0325
Knock Sensor (KS) Circuit
DTC P0327 or P0332
Knock Sensor Circuit
DTC P0336
Crankshaft Position (CKP) Sensor Circuit
DTC P0341
Camshaft Position (CMP) Sensor Performance
DTC P0401
Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0403
Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
DTC P0404
Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405
Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0420
Catalyst System Low Efficiency
DTC P0442
Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446
Evaporative Emission (EVAP) Vent System Performance
DTC P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452
Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453
Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0455
Evaporative Emission System Leak Detected
DTC P0462
Fuel Level Sensor Circuit Low Voltage
DTC P0463
Fuel Level Sensor Circuit High Voltage
DTC P0480 or P0481
Cooling Fan Relay Control Circuit
DTC P0496
Evaporative Emission System High Purge Flow
DTC P0502
Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506
Idle Speed Low
DTC P0507
Idle Speed High
DTC P0522
Engine Oil Pressure (EOP) Sensor Circuit Low Voltage
DTC P0523
Engine Oil Pressure (EOP) Sensor Circuit High Voltage
DTC P0530
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0560
System Voltage
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610
ECU Malfunction
DTC P0620
Generator Performance
DTC P0641
Sensor Reference Voltage "A" Circuit/Open
DTC P0645
A/C Clutch Relay Control Circuit
DTC P0650
Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0651
Sensor Reference Voltage "B" Circuit/Open
DTC P0711
TFT Sensor Circuit Range/Performance
DTC P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0716
Input Speed Sensor Circuit Intermittent
DTC P0717
Input Speed Sensor Circuit Low Input
DTC P0719
Brake Switch Circuit Low Input
DTC P0724
Brake Switch Circuit High Input
DTC P0730
Incorrect Gear Ratio
DTC P0741
TCC System Stuck Off
DTC P0742
TCC System Stuck On
DTC P0748
Pressure Control Solenoid Circuit Electrical
DTC P0751
1-2 Shift Solenoid Valve Performance
DTC P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear
DTC P0753
1-2 Shift Solenoid Circuit Electrical
DTC P0756
2-3 Shift Solenoid Valve Performance
DTC P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear
DTC P0758
2-3 Shift Solenoid Circuit Electrical
DTC P1106
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1112
Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121
Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122
Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1133
HO2S Insufficient Switching Sensor 1
DTC P1134
HO2S Transition Time Ratio Sensor 1
DTC P1351
Ignition Coil Control Circuit High Voltage
DTC P1352
Ignition Bypass Circuit High Voltage
DTC P1361
Ignition Control (IC) Circuit Low Voltage
DTC P1362
Ignition Bypass Circuit Low Voltage
DTC P1374
Crankshaft Position (CKP) High to Low Resolution Frequency Correlation
DTC P1380
Misfire Detected - Rough Road Data Not Available
DTC P1381
Misfire Detected - No Communication with Brake Control Module
DTC P1404
Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1536
Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
DTC P1540
Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
DTC P1554
Cruise Control Feedback Circuit
DTC P1575
Extended Travel Brake Switch Circuit
DTC P1585
Cruise Control Inhibit Output Circuit
DTC P1626
Theft Deterrent Fuel Enable Signal Lost
DTC P1630
Theft Deterrent Learn Mode Active
DTC P1631
Theft Deterrent Start Enable Signal Not Correct
DTC P1640
Control Module Output A Circuit
DTC P1650
Control Module Output B Circuit
DTC P1660
Control Module Output C Circuit
DTC P1670
Control Module Output D Circuit
DTC P1811
Maximum Adapt and Long Shift
DTC P1814
Torque Converter Overstressed
DTC P1819
Internal Mode Switch-No Start/Wrong Range
DTC P1820
Internal Mode Switch Circuit A Low
DTC P1822
Internal Mode Switch Circuit B High
DTC P1823
Internal Mode Switch Circuit P Low
DTC P1825
Internal Mode Switch - Invalid Range
DTC P1826
Internal Mode Switch C Circuit High Voltage
DTC P1860
TCC PWM Solenoid Circuit Electrical
DTC P1887
TCC Release Switch Circuit
DTC U1000 and U1255
Class 2 Communication Malfunction
DTC U1001-U1254
Lost Communications With XXX
DTC U1161-U1163 or U1170
Lost Communications With XXX Door Module
DTC U1300, U1301, or U1305
Class 2 Data Link Low or High
DTC U1500
Inter-device Dedicated Bus 1
