Anti-Lock Brake Light is onbajafiend 03-11-2004, 01:56 PM Whats the deal when the Anti Lock brake light is on? My brakes work fine.. I think. Is there a fix or something to watch for? 1995 1500 z-71 ext cab juma33 03-13-2004, 08:45 PM it means your anti-lock system isn't working. your brakes will still work but you won't be able to getanti-lock on ice or wet pavement. Its probably a sh#t load of bux to fix it. I'd just drive it and remember you can't stop as well on ice and water. juma 98sierraman 03-13-2004, 09:50 PM Chances are that on your front brakes, driver or passenger side the wires for your abs sensor has broken. take a look and follow the sensor wire and check for broken wires. 90 % of the time it will be the passenger side. This is fixable with wire conectors and electrical tape. It also might be a bad sensor, but check it out! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
