03 Stall Problem
Google
Web AF
Seanscho
03-10-2004, 01:15 AM
My 03 has been stalling randomly as the car slows down to a stop. It it doesn't stall, the tach drops to around and under 500RPMs. It's happened a few times now, but it freaks me out, because you know how hard a car is to control when turning into a parking spot and it stalls... Help!
amac209
03-10-2004, 07:55 AM
sounds like waranty to me.
ksparticuspa
03-10-2004, 10:01 AM
i don't know if they are still set up this wasy, but my friends '93 had the same problem - found out it was the electronic locking torque converter in the transmission - unplugged it the car's been fine for about a year and a half now
studballs
03-10-2004, 01:12 PM
its more likely in need of a PCM update...there have been many others with the same problem...
FlLibraRat
03-18-2004, 05:13 PM
Mine has been doing this since day one! Especially right around 1/4 of a tank. It's been serviced, recalled, updated and had sensors replaced. Nothing helped. I think the 03 is a general lemon.
amac209
03-18-2004, 06:43 PM
keep hassling your dealer. you paid for the warranty and they have to fix it. parts aren't cheap for these things you don't wanna have to pay for them when the warranty runs out. good luck in your fight!
jimenemd
06-20-2004, 10:03 PM
I have the same problem...take it to the dealership and tell them to search for a technical service bulletin that was issued on Jan 1, 2004. I beleive that bulletin addresses the problem. I'm going to take my car this week to get it serviced.
Also, your state's lemon law (try this first before hiring a lawyer) will do the job!!!
Classicrocjunkie
06-20-2004, 10:40 PM
If under 36K..which i hope it would be for an 03 tell them you want it fixed. And if something keeps going wrong with it, its the dealers fault and they have to continue fixing it, untill it is fixed!
foreverablonde_21
06-23-2004, 10:11 PM
My car had the same problem. There is bulletin out on the IAC valve. Check with your dealership, it also may be caused by erratic fuel pump pressure. I had both of these replaced about a month ago. Hope this helps.
Google
Web AF
