lift and tirescalebbarry 03-09-2004, 08:25 PM Hi guys i have a 02 trd 4x4 and would like to know if i were to put a 3in lift what size tires could i put on it i have the 16in wheels Thanks alot scott02 03-10-2004, 06:44 PM I too have a 2002 tacoma. Ijust put a performance accessories 3'' body lift on. I have mickey thompson classic 2 wheels 16x8 with 4 7/16ths backspacing. Iam waiting for the tires to come i ordered bfgoodrich allterrrain. in 285/75/16. From all the searching i did these should fit no problem. When i get the tires monted on saturday i will tell you how they fit. Scott :biggrin: What rims do you have the stock rims. dfskinner 03-11-2004, 08:28 AM Actually, I'd like to get a sampling of what you guys have paid for a 4" lift. I got a quote of $ 400.00 from "Eastern Off-Road", and I wanted to make sure I'm not paying too much. scott02 03-11-2004, 05:14 PM I paid 221.69 for a 3'' body lift from summit racing. I installed it with my friend and it took about six hours. There is some welding required to extend the shifters. And to weld bed crush blocks, and weld brackets for the gap guards. Gap guards were separte 59.95. :) superjoe83 03-12-2004, 04:40 AM i have a '99 taco and with a 3" coilover lift i can fit 33x12.5's with minor rubbing when turning scott02 03-13-2004, 04:30 PM Well the tires are mounted on the rims and the rims hit the front caliper that rim dosent fit the 02 tacoma. Igrounf the caliper and still couldnt get it on. :banghead: .Then i put a hole in caliper wow that sucks :mad: .I think i should have went with the smaller backspacing. But those tires fit in the wheel whells nice. scott02 03-14-2004, 04:33 PM Well found out all i needed was a 1/4 spacer behind the wheel, and to install longer rear wheel studs up front because of the spacer and everything is good. no rubing, nice. :smile: Snobrdrblinkchik 04-25-2004, 01:32 AM Actually, I'd like to get a sampling of what you guys have paid for a 4" lift. I got a quote of $ 400.00 from "Eastern Off-Road", and I wanted to make sure I'm not paying too much. What kind of lift are you gettin' where it'll get you 4" for only $400??? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
