Fuel system problemOOmega 03-08-2004, 07:42 PM I have an 89 Cabriolet Wolfsburg, 150K strong, Manual. I have had an ongoing fuel problem. The car will run great for an over an hour, then when I stop at a light it shuts off. If I shift, sometimes the car will buck like a horse, then when I step on the gas there is no responce. Sometimes it will not want to turn on after that. I am sure the problem is with the fuel system. The only reason all of this happens is because the car is not getting gas; the gas petal becames unreponsive. When this all happens I hear a buzzing noisecomming from the fuel pump and when the car is about to shut off it makes a high pitched whining noise. I have replaced the fuel pump with a Bosch fuel pump and changed the fuel filter. So I am sure these cannot be the problem. Besides this problem the car is great. I hope you can help me. THANKS dogcab 08-16-2007, 10:05 PM I battled similar frustrations...check the fuel pump inside the gas tank....:smooch: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
