Helpelliottdl 03-08-2004, 07:38 PM I have a 1984 K1500 4x4. My problem is that the left rear flasher does not work when the Hazzard lights are on BUT it works when just using the turn signal!!! Any ideas as to what the problem might be????? Thanks quaddriver 03-08-2004, 11:35 PM I have a 1984 K1500 4x4. My problem is that the left rear flasher does not work when the Hazzard lights are on BUT it works when just using the turn signal!!! Any ideas as to what the problem might be????? Thanks check for a burned bulb anywhere and get a constant load-independant flasher and you should be fine. both systems use the same rear wiring from the dash panel back, but are fed differently elliottdl 03-09-2004, 08:03 AM Thanks for your reply I will try that. Thanks again Mark_in_NY 03-10-2004, 08:32 PM You may have a bad ground back feeding through the other taillamp circuit. When the flashers are on both ciruits are energized and the "alternate" path is no longer available. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
