general engine question
CKAMC
03-07-2004, 05:19 AM
ok i have a 95 se-r with the sr20de sitting inside it. i wonder what engines i can upgrade to that will fit the current tranny and will out perform the 20de. please include specs or links. ty for your time
PS will it bolt in easy or will it take some work and it will fit in?
fugiot
03-12-2004, 03:19 PM
You have a few choices
A Front wheel drive SR20DET(205hp stock)
A front wheel drive SR20VE(190hp stock)
or bolt on's for your SR20DE
With the DET you could be running mid 13's in the 1/4 and with the VE you probably be running high 13's. If you're looking for an easy performance upgrade tho, just look into modding your DE. You're probably running about a 16 flat in the stock SE-R now and with a few good bolt-ons you can hit mid-low 14's. It's all about your budget. If you have less than $3500 or so to spend at a time, then just look into bolt-ons. Acceleration matching an S2000 isn't too shabby! PM if you want more details about mods and their effectiveness
B14Boost
07-21-2004, 03:23 AM
Pulsar GTI-R would work too. Its an All wheel drive tranny, but will bolt onto the SE-R tranny. You would want limited slip though, otherwise, good luck with traction.
fugiot
07-21-2004, 05:06 AM
All SE-R's some with an LSD stock.
200SXGTi-R
07-21-2004, 08:04 AM
the stock lsd in the se-r tranny is no good its viscous and wears out after a few hundred miles. it only came up to 97. A SR20ve swap will only give you mid to high 14's with intake headers and exhaust a little more mods on it will give you high 13 and low 14 but expensive parts and hard to find.
fugiot
07-22-2004, 12:58 AM
hmm, I didn't think there was much difference in the times from B13 to B14. Cause a B13 with the VE will run around a 14.0 with no mods other than the engine itself.
200SXGTi-R
07-22-2004, 10:33 PM
i doubt that, i know a few VE's , and the ones that run those numbers have mods. something is up with that engine
