how to change trunk speakers in a 97 civic lxmynameisholly 03-05-2004, 11:04 AM i was wondering if anyone could tell me how to change my trunk speakers in my 97 civic. i want to do it myself but i dont know if you need a specific kind of speaker or what. and also i dont want to damage anything in the process. THANKS! steve8091 03-05-2004, 12:18 PM Head over to www.crutchfield.com. They are expensive, so you don't necessarily need to buy from them, but they'll tell you what size speakers you need. So long as they are the right size, and assuming you have a stock head unit, they will work. A GUESS would be that you have 6"x9" back there. As far as removal, there are probably a few screws and/or clips holding on the moulding, and 3 or 4 screws holding on the speaker. Once you get all of those out, there should be a quick disconnect harness from which you can unhook the old speaker and hook up the new. Good luck. defmusik 03-06-2004, 12:42 AM 1: Pull down the rear seats 2: Unscrew them from the brackets and take them out 3: Remove the bottom parts of the seats (mine were taken off before so I could just take them right out, I dunno if theres any bolts) 4: Remove the side panels on both sides (they snap off easy) 5: Remove the top part of the rear of the car (the piece that has the break light attatched (which you need to disconnect first) 6: Disconnect the rear speakers, and unscrew them from the top 7: Install aftermarket speakers, and go backwards!! ===This took me about an hour to completely finish and rewire=== Any other questions just reply EDIT: Yes they are 6x9 in the rear (coupe, not sure about HB) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
