Clearance Light 3rd Screw
frogg
01-04-2002, 08:39 PM
Which screw is the 3RD SCREW?
I have read all of the posts on here and still do not know which one is the last one connecting the headlight.
I tried to take a picture so just try to help me out here.
Is this the screw or is it below? Pictures would be appreciated :D
frogg
01-05-2002, 12:44 AM
Cmon guys! I know lots of you have done this!
b-b00gie
01-05-2002, 10:54 AM
Hmm.. I could've sworn a posted a pic about this a LONG time ago. Or maybe I emailed it to someone privately?
I'll do some looking.. but thats NOT the screw. That adjusts your beam angle. Its about 1 or 2 inches below that one and it does not stick out.
frogg
01-05-2002, 11:49 AM
Ok, is it the one that is just a bolt with a nut on it right below that one? Because the one at the very bottom just holds the fans on.
So it's the one in-between these two right?
b-b00gie
01-05-2002, 01:46 PM
Oh.. I didnt realize that was the other headlight...
Anyhow... here's one headlight. The "3rd bolt/nut" is in the same place on both lights. Pay no mind to the beam adjustment bolt...
frogg
01-05-2002, 02:25 PM
Thanks b-boogie, thats gonna help alot.
Also, how did you get out the main headlight bulb? It's held in there by a little metal wire.. :mad:
b-b00gie
01-05-2002, 02:48 PM
The manual should have a description and pictures but...
1) pull the connector off
2) pull that black rubber thing off
3) theres a metal clip that holds the bulb in, there a tab on it and all you do is push it down and to the side to get it to unlock....
frogg
01-05-2002, 04:46 PM
Sorry for being lazy and not looking in the manual.
Ok I got the connector loose and look what I found:
frogg
01-05-2002, 07:38 PM
What is this crap?
frogg
01-05-2002, 07:40 PM
Bulb looks broken, theres a disconnected piece rolling around inside..
The bulb says 85/100W H4 so I think the guy stuck a too high wattage bulb in..
b-b00gie
01-05-2002, 07:46 PM
Yep, thats what happens... eventually the whole thing melts and turns into a mucky mess...
frogg
01-05-2002, 07:49 PM
So, from that picture, can you tell if I need to replace my harness or not? You think I could possibly clean it out and be fine with the stock headlight bulbs?
