what should i do
montemami
03-03-2004, 11:51 AM
i have a 87 monte carlo ss and i would really like to work on it this year since im allready working on my other car if anyone has any suggestions what i should do to it comment please im thinking about putting a big block in it but i dont kno the specifics yet allready have a flowmaster on it someone told me to put a glass pack on it but.. dont kno yet i want to put new darker tints maybe ground effects and possiably new t tops the first thing is defintly rebuilting the engine or a new one sooo if anyone has anything they think i should add please tell me thnxs :biggrin:
amac209
03-04-2004, 08:06 AM
i think i'd stick to a small block. lighter weight and they rev higher without blowing apart. i'd find a good block bore it .030 over get some forged 10.5:1 pistons, vortec heads GM performance intake 750 cfm carb, 280 degree cam with around .5" lift, big headers & 3" exhaust with big mufflers, msd ingition, K&N filter. this engine set up is good for around 400+hp&400+ft-lbs with a redline at about 6300. turbo400 tranny stage 2 shift kit, B&M rachet shifter, 1600rpm stall speed convertor. GM 12 bolt diff 3.42 gears auburn gears posi. of course thats what i would do my buddy has a similar set up in his chevelle and it breaks the tires loose when it shifts into drive. if that isn't enough add a 150 shot of nitrus and a 4340 forged crank with 4340 forged rods. man that would be the ultimate rice killer!! if it were me i'd try to leave the body as stock as possible except for big ass tires on the back.
montemami
03-04-2004, 08:46 AM
u kno what i think ur right lol just to show those ricers whose boss!!!
montemami
03-16-2004, 11:10 AM
would nitrous do the trick??!!
Ironman_375
03-16-2004, 06:42 PM
I'd only use nos if you were positive that your engine could handle it...make sure your cylinders are in good shape, along with your connecting rod's, pistons,
etc
montemami
03-17-2004, 11:18 AM
what could happen if i put nos in it and my engine cant handle it would i combust into flames???
amac209
03-17-2004, 04:22 PM
the regular effects of detenation: blown pistons, broken rods, broken crank, dished valves not much fun. if you have a strong engine and some way of retarding the timing it should be fine.
montemami
03-18-2004, 09:07 AM
ohh ok thanxs guys i appreciate the help
