Intake Manifold Gasketi live in a box 03-03-2004, 02:56 AM I bought a used Jeep GC today. I bought it full knowing that there are a few repairs, so I also purchased a 30,000/ 2 year extended Mechanical Breakdown warranty through my credit union. The plan activates after I drive the vehicle 1,000 miles and I must own the vehicle for 1 full month. I was wondering if there is anybody who has ever had an intake manifold gasket problem which affected the idle and whether stretching it out 1,000 miles is a hazard to the engine. There is no check engine lights on yet, but I suspect that there will be. Is it advisable to wait? Don't be afraid to voice your opinions. I take full responsibility for my final desicion. R_WALDO_86 03-04-2004, 12:31 AM i've had a dime size hole in my manifold for well over a year, and it hasn't caused any problems, just sounds like a damned bumble bee haha R_WALDO_86 03-04-2004, 12:31 AM oops sorry misread your post, mine was on the exhaust manifold Comet 3995 04-03-2004, 12:56 PM If the idle isn't too bad, you should be ok for a short time. It will throw the mixtuure off a bit. I just fixed my leaking manifold gasket and the engine is smoooooth now at idle. My last GC had a manifold leak for about three years and aside from a rough idle, it ran great and got fantastic mileage. Dale Aeppli 04-03-2004, 04:44 PM HI YOU COULD TRY TIGHTENING THE MANIFOLD BOLTS, MIGHT BE ENOUGH TO HELP YOU OUT. DALE jeepman600@aol.co don't break the off try to tighten them a equal amount, leowolf 05-04-2004, 06:09 PM HI YOU COULD TRY TIGHTENING THE MANIFOLD BOLTS, MIGHT BE ENOUGH TO HELP YOU OUT. DALE jeepman600@aol.co don't break the off try to tighten them a equal amount, Dales right but make sure you get the correct torque spec. and use a torque wrench. A broken intake manifold will most deffinetly compound your problem. can anyone offer the torque spec. from a manual on hand? leowolf dksob81 09-15-2004, 03:50 AM 5.2 and 5.9L= step 1 6f t/lbs , step 2 12 ft/lbs 4.0L= 24 ft/lbs vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
