brake and battery dash lights are onhealthmj 03-02-2004, 09:15 PM I have a 1997 Isuzu Rodeo and can anyone tell me why my brake and battery dash lights came on? Thanks in advance Mike Jeansonne rodeo02 03-02-2004, 09:25 PM This the classic symptoms of your charging system not maintaining 14v with the truck running. Most common cause is a bad alternator (only use OEM replacement), old tired battery, battery terminal, connection/ cable, or grounding issue. G/luck Joel amigo-2k 03-02-2004, 09:44 PM Joel - hit it on the head! 1. Clean up the battery connection including were it grounds to the body 2. if your battery is 4-5 years old replace it 3. if the lights come back replace the alt. -Ryan healthmj 03-02-2004, 10:02 PM Joel - hit it on the head! 1. Clean up the battery connection including were it grounds to the body 2. if your battery is 4-5 years old replace it 3. if the lights come back replace the alt. -Ryan Will do. I'll do it tomorrow. Thanks a bunch healthmj 03-02-2004, 10:04 PM This the classic symptoms of your charging system not maintaining 14v with the truck running. Most common cause is a bad alternator (only use OEM replacement), old tired battery, battery terminal, connection/ cable, or grounding issue. G/luck Joel I'll clean and check the battery connections first and then hope and pray Thanks Mike Jeansonne healthmj 03-09-2004, 09:29 PM I got my car serviced by my mechanic. He replaced the alternator. My alternator gauge is showing approximately 13 volts versus 10 volts. Thanks for your help and suggestions Percon 03-10-2004, 12:22 PM I have the same problem before on my 98 Rodeo.you have to change the alternator. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
