Feeling Knocking in Clutch Pedalkrimes13 03-01-2004, 01:03 AM Got a '96 Passport(you know, the rodeo with a H on the front) 4X4, 3.2L V6, 5 speed 115k miles. It's knocking pretty good at idle, and gets really excessive when giving gas and letting out on the clutch. Apparently it's not a major problem, it's been going on for about 10k miles. Was told to replace the pilot bearing. Replaced clutch, pressure plate, throw-out bearing, and pilot bearing. Didn't help sound, but drives better. Always seems to be quieter for a day or so after a fresh oil change. Wondering about oil pump/pick-up issues or some main bearings but that would not explain the knocking on the clutch pedal (I don't think). Dan106 03-01-2004, 07:55 PM I believe you might have more than one problem. I do not see how a knocking at idle and then a knocking in the clutch pedal could be from the same problem. Have someone check the motor compartment as you pull forward & backward to try and locate the general area of the problem. Sorry this reply is not a fix for the problem. krimes13 03-02-2004, 03:26 PM Yeah, it's got me perplexed as well. I do know that they are definitely related because it is the same "rythm" under the hood and my foot. Any more suggestions are greatly appreciated! 2eyefishclaw 03-02-2004, 10:35 PM maybe something is busted/broken rodeo02 03-02-2004, 11:01 PM Could this be the old worn out timing belt tensioner knock thing? T-belt slaps against a t-belt cover. Sounds like a rod-knock. Pull the t-belt covers & see if the noise goes away. G/luck Joel krimes13 03-05-2004, 10:49 AM The t-belt and all associated components have been visually inspected and seem up to par. Still looking for the top of my right index knuckle. Didn't actually remove the push-rod tensioner to check the tensioner and idler bearings but, pretty sure thats not part of the problem. Still searching and brain-storming. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
