98 bonneville no HEAT (BRRRRR)
ro25
02-25-2004, 10:41 AM
I have a 98 bonneville and for about 2 weeks now i am not getting any heat.. initially i thought it was the coolant/water mixture as i was using close to pure coolant as there was a leak and never put in water just coolant. But now the temperature is flashing on my climate control and no matter was temperature i put it on im getting cold air.
Its winter and i would love to get some heat.
i think i can hear the actuator running but i could be wrong. Anyone have any idea how i can fix this???
Thanks
Ro
FFrank
02-27-2004, 02:44 AM
Are you sure you are not just very low on coolant? Open the rad cap when engine is cold and have a look. If you are down alot no water will reach the heater core.
JJ052653
02-27-2004, 08:22 AM
Please check the tread, HEater Core Replacement 1996 Bonneville
markwb
02-29-2004, 08:46 AM
It sounds like the door actuator might not be functioning properly. This makes the climate control system inoperable. Is the fan operating? Also check the inlet & outlet hoses to the heater core to see if they're hot.
Flatrater
02-29-2004, 02:34 PM
If the display is flashing on your HVAC head that means you has a problem and it should have a stored code.
ro25
03-01-2004, 09:01 AM
thanks for the info guys.. but couple of days ago i was driving on the highway and when i exited, the check engine light came on and the engine began to run eratically i pulled over and the engine stalled, i tried to restart but it wouldnt even turn over. i figured i had blowed my engine but it never got hot, oil wasnt even that hot. But i had no more coolant in the vehicle. I had it towed home. And i began taking the engine apart. I have now discovered that i have a crack in my head gasket and the coolant was getting into the engine.
so now the engine is in a hundred parts, i have to go buy a few gaskets and hopfully put this thing back together.. just hope i know what screw goes where.
can anyone offer any advise on how i can flush the water out of my system?
Thanks
Ro
and now i know why i didnt have heat for a week. the water never made it to the heater core, steaming away in the engine. weird think was there wasnt any unusual amount of steam from the exhaust??? weird.
