Check engine light
lcjr
02-24-2004, 09:58 PM
Hi,
We have a 2000 Dodge Durango and the check engine light has come on. We read about the ignition switch "trick" to get the code and were wondering if anybody knows what the code P 0700 means.
Please let us know
Thanks in advance
ctd
02-28-2004, 05:44 PM
I sent you a pm if you didn't get it let me know and I will look up your code again.
Gordie
lcjr
02-29-2004, 10:32 AM
Gordie
Thanks,
We got it taken care of. This board is great. Some reading, 30 minutes under the truck, and $11 later the broblem is fixed. Turned out to be the speed sensor. Since it has two and we had no way of telling wich one went bad we replaced both. After about 3 miles of driving the check engine light went out and the truck shifts just fine now.
Thanks again
allycatz
05-27-2004, 06:33 PM
My engine light is on also. How do I get the pm?
ctd
05-27-2004, 08:16 PM
What code does it read, let me know and I will let you know what your problem is.
Gordie
kellerrl
06-15-2004, 01:15 AM
Gordie
How do you get the error code? My 2000 Durango, transmission is in the limp mode (only goes into 2nd gear), and the engine light is on (it came on the day before the transmission wouldn't come out of second gear). I would like to know how to get the error code.
Randy
rod2envy
06-15-2004, 12:05 PM
Hi,
Do you mind if I ask you something, what kind of erratic shifting were you getting? I'm having some hard shifting problems on my 98 Durango and was thinking may be the same fix as yours. Also where are this 2 speed sensors located on the durango? and how did you ordered them. Thanks in advance for the help.
Damian
Thanks,
Thanks again
